test set
A company plans to use an Amazon Snowball Edge device to transfer files to the AWS Cloud. Which activities related to a Snowball Edge device are available to the company at no cost?
Use of the Snowball Edge appliance for a 10-day period
The transfer of data out of Amazon S3 and to the Snowball Edge appliance
The transfer of data from the Snowball Edge appliance into Amazon S3
Daily use of the Snowball Edge appliance after 10 days
A company has deployed applications on Amazon EC2 instances. The company needs to assess application vulnerabilities and must identify infrastructure deployments that do not meet best practices. Which AWS service can the company use to meet these requirements?
AWS Trusted Advisor
Amazon Inspector
AWS Config
Amazon GuardDuty
A company has a centralized group of users with large file storage requirements that have exceeded the space available on premises. The company wants to extend its file storage capabilities for this group while retaining the performance benefit of sharing content locally. What is the MOST operationally efficient AWS solution for this scenario?
Create an Amazon S3 bucket for each user. Mount each bucket by using an S3 file system mounting utility.
Configure and deploy an AWS Storage Gateway file gateway. Connect each user’s workstation to the file gateway.
Move each user’s working environment to Amazon WorkSpaces. Set up an Amazon WorkDocs account for each user.
Deploy an Amazon EC2 instance and attach an Amazon Elastic Block Store (Amazon EBS) Provisioned IOPS volume. Share the EBS volume directly with the users.
According to security best practices, how should an Amazon EC2 instance be given access to an Amazon S3 bucket?
Hard code an IAM user’s secret key and access key directly in the application, and upload the file.
Store the IAM user’s secret key and access key in a text file on the EC2 instance, read the keys, then upload the file.
Have the EC2 instance assume a role to obtain the privileges to upload the file.
Modify the S3 bucket policy so that any service can upload to it at any time.
Which option is a customer responsibility when using Amazon DynamoDB under the AWS Shared Responsibility Model?
Physical security of DynamoDB
Patching of DynamoDB
Access to DynamoDB tables
Encryption of data at rest in DynamoDB
