AZ-700 Exam
Your company has a single on-premises datacenter in Washington DC. The East US Azure region has a peering location in Washington DC.
The company only has Azure resources in the East US region.
You need to implement ExpressRoute to support up to 1 Gbps. You must use only ExpressRoute Unlimited data plans. The solution must minimize costs.
Which type of ExpressRoute circuits should you create?
ExpressRoute Local
ExpressRoute Direct
ExpressRoute Premium
ExpressRoute Standard
You are planning an Azure Point-to-Site (P2S) VPN that will use OpenVPN.
Users will authenticate by an on-premises Active Directory domain.
Which additional service should you deploy to support the VPN authentication?
an Azure key vault
a RADIUS server
a certification authority
Azure Active Directory (Azure AD) Application Proxy
#3 Multiple Choice
You plan to configure BGP for a Site-to-Site VPN connection between a datacenter and Azure.
Which two Azure resources should you configure? Each correct answer presents a part of the solution. (Choose two.)
a virtual network gateway
Azure Application Gateway
Azure Firewall
a local network gateway
Azure Front Door
You fail to establish a Site-to-Site VPN connection between your company's main office and an Azure virtual network.
You need to troubleshoot what prevents you from establishing the IPsec tunnel.
Which diagnostic log should you review?
IKEDiagnosticLog
RouteDiagnosticLog
GatewayDiagnosticLog
TunnelDiagnosticLog
#5 Multiple Choice
You have an Azure virtual network and an on-premises datacenter.
You are planning a Site-to-Site VPN connection between the datacenter and the virtual network.
Which two resources should you include in your plan? Each correct answer presents part of the solution.
a user-defined route
Azure Firewall
Azure Web Application Firewall (WAF)
an on-premises data gateway
an Azure application gateway
G.
