AWS Certified Developer - Associate DVA-C02
A company is migrating legacy internal applications to AWS. Leadership wants to rewrite the internal employee directory to use native AWS
services. A developer needs to create a solution for storing employee contact details and high-resolution photos for use with the new application.
Which solution will enable the search and retrieval of each employee's individual details and high-resolution photos using AWS APIs?
Encode each employee's contact information and photos using Base64. Store the information in an Amazon DynamoDB table using a sort
key.
Store each employee's contact information in an Amazon DynamoDB table along with the object keys for the photos stored in Amazon S3.
Use Amazon Cognito user pools to implement the employee directory in a fully managed software-as-a-service (SaaS) method.
Store employee contact information in an Amazon RDS DB instance with the photos stored in Amazon Elastic File System (Amazon EFS).
A developer is creating an application that will give users the ability to store photos from their cellphones in the cloud. The application needs to
support tens of thousands of users. The application uses an Amazon API Gateway REST API that is integrated with AWS Lambda functions to
process the photos. The application stores details about the photos in Amazon DynamoDB.
Users need to create an account to access the application. In the application, users must be able to upload photos and retrieve previously
uploaded photos. The photos will range in size from 300 KB to 5 MB.
Which solution will meet these requirements with the LEAST operational overhead?
Use Amazon Cognito user pools to manage user accounts. Create an Amazon Cognito user pool authorizer in API Gateway to control
access to the API. Use the Lambda function to store the photos and details in the DynamoDB table. Retrieve previously uploaded photos
directly from the DynamoDB table.
access to the API. Use the Lambda function to store the photos in Amazon S3. Store the object's S3 key as part of the photo details in the
DynamoDB table. Retrieve previously uploaded photos by querying DynamoDB for the S3 key. Most Voted
Create an IAM user for each user of the application during the sign-up process. Use IAM authentication to access the API Gateway API. Use
the Lambda function to store the photos in Amazon S3. Store the object's S3 key as part of the photo details in the DynamoDB table. Retrieve
Create a users table in DynamoDB. Use the table to manage user accounts. Create a Lambda authorizer that validates user credentials
against the users table. Integrate the Lambda authorizer with API Gateway to control access to the API. Use the Lambda function to store the
photos in Amazon S3. Store the object's S3 key as par of the photo details in the DynamoDB table. Retrieve previously uploaded photos by
A company receives food orders from multiple partners. The company has a microservices application that uses Amazon API Gateway APIs with
AWS Lambda integration. Each partner sends orders by calling a customized API that is exposed through API Gateway. The API call invokes a
shared Lambda function to process the orders.
Partners need to be notified after the Lambda function processes the orders. Each partner must receive updates for only the partner's own orders.
The company wants to add new partners in the future with the fewest code changes possible.
Which solution will meet these requirements in the MOST scalable way?
Create a different Amazon Simple Notification Service (Amazon SNS) topic for each partner. Configure the Lambda function to publish
messages for each partner to the partner's SNS topic.
Create a different Lambda function for each partner. Configure the Lambda function to notify each partner's service endpoint directly.
Create an Amazon Simple Notification Service (Amazon SNS) topic. Configure the Lambda function to publish messages with specific
attributes to the SNS topic. Subscribe each partner to the SNS topic. Apply the appropriate filter policy to the topic subscriptions. Most Voted
Create one Amazon Simple Notification Service (Amazon SNS) topic. Subscribe all partners to the SNS topic.
A financial company must store original customer records for 10 years for legal reasons. A complete record contains personally identifiable
information (PII). According to local regulations, PII is available to only certain people in the company and must not be shared with third parties.
The company needs to make the records available to third-party organizations for statistical analysis without sharing the PII.
A developer wants to store the original immutable record in Amazon S3. Depending on who accesses the S3 document, the document should be
returned as is or with all the PII removed. The developer has written an AWS Lambda function to remove the PII from the document. The function
is named removePii.
What should the developer do so that the company can meet the PII requirements while maintaining only one copy of the document?
Set up an S3 event notification that invokes the removePii function when an S3 GET request is made. Call Amazon S3 by using a GET
request to access the object without PII.
Set up an S3 event notification that invokes the removePii function when an S3 PUT request is made. Call Amazon S3 by using a PUT
Create an S3 Object Lambda access point from the S3 console. Select the removePii function. Use S3 Access Points to access the object
without PII. Most Voted
Create an S3 access point from the S3 console. Use the access point name to call the GetObjectLegalHold S3 API function. Pass in the
removePii function name to access the object without PII.
A developer is deploying an AWS Lambda function The developer wants the ability to return to older versions of the function quickly and
seamlessly.
How can the developer achieve this goal with the LEAST operational overhead?
Use AWS OpsWorks to perform blue/green deployments.
Use a function alias with different versions. Most Voted
Maintain deployment packages for older versions in Amazon S3.
Use AWS CodePipeline for deployments and rollbacks.
