DP-203 Exam
You are designing the folder structure for an Azure Data Lake Storage Gen2 container.
Users will query data by using a variety of services including Azure Databricks and Azure Synapse Analytics serverless SQL pools. The data will be secured by subject area. Most queries will include data from the current year or current month.
Which folder structure should you recommend to support fast queries and simplified folder security?
/{SubjectArea}/{DataSource}/{DD}/{MM}/{YYYY}/{FileData}{YYYY}.csv}_{DD
/{DD}/{MM}/{YYYY}/{SubjectArea}/{DataSource}/{FileData}{YYYY}.csv}_{DD
/{YYYY}/{MM}/{DD}/{SubjectArea}/{DataSource}/{FileData}{YYYY}.csv}_{DD
/{SubjectArea}/{DataSource}/{YYYY}/{MM}/{DD}/{FileData}{YYYY}.csv}_{DD
You need to output files from Azure Data Factory.
Which file format should you use for each type of output? To answer, select the appropriate options in the answer area.
You use Azure Data Factory to prepare data to be queried by Azure Synapse Analytics serverless SQL pools.
Files are initially ingested into an Azure Data Lake Storage Gen2 account as 10 small JSON files. Each file contains the same data attributes and data from a subsidiary of your company.
You need to move the files to a different folder and transform the data to meet the following requirements:
✑ Provide the fastest possible query times.
✑ Automatically infer the schema from the underlying files.
How should you configure the Data Factory copy activity? To answer, select the appropriate options in the answer area.
You have a data model that you plan to implement in a data warehouse in Azure Synapse Analytics as shown in the following exhibit.
All the dimension tables will be less than 2 GB after compression, and the fact table will be approximately 6 TB. The dimension tables will be relatively static with very few data inserts and updates.
Which type of table should you use for each table? To answer, select the appropriate options in the answer area.
You have an Azure Data Lake Storage Gen2 container.
Data is ingested into the container, and then transformed by a data integration application. The data is NOT modified after that. Users can read files in the container but cannot modify the files.
You need to design a data archiving solution that meets the following requirements:
✑ New data is accessed frequently and must be available as quickly as possible.
✑ Data that is older than five years is accessed infrequently but must be available within one second when requested.
✑ Data that is older than seven years is NOT accessed. After seven years, the data must be persisted at the lowest cost possible.
✑ Costs must be minimized while maintaining the required availability.
How should you manage the data? To answer, select the appropriate options in the answer area.
NOTE: Each correct selection is worth one point
