DP-203 Exam
You need to create a partitioned table in an Azure Synapse Analytics dedicated SQL pool.
How should you complete the Transact-SQL statement? To answer, drag the appropriate values to the correct targets. Each value may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
You need to design an Azure Synapse Analytics dedicated SQL pool that meets the following requirements:
✑ Can return an employee record from a given point in time.
✑ Maintains the latest employee information.
✑ Minimizes query complexity.
How should you model the employee data?
as a temporal table
as a SQL graph table
as a degenerate dimension table
as a Type 2 slowly changing dimension (SCD) table
#13 Multiple Choice
You have an enterprise-wide Azure Data Lake Storage Gen2 account. The data lake is accessible only through an Azure virtual network named VNET1.
You are building a SQL pool in Azure Synapse that will use data from the data lake.
Your company has a sales team. All the members of the sales team are in an Azure Active Directory group named Sales. POSIX controls are used to assign the
Sales group access to the files in the data lake.
You plan to load data to the SQL pool every hour.
You need to ensure that the SQL pool can load the sales data from the data lake.
Which three actions should you perform? Each correct answer presents part of the solution.
NOTE: Each area selection is worth one point.
Add the managed identity to the Sales group.
Use the managed identity as the credentials for the data load process.
Create a shared access signature (SAS).
Add your Azure Active Directory (Azure AD) account to the Sales group.
Use the shared access signature (SAS) as the credentials for the data load process.
Create a managed identity.
You have an Azure Synapse Analytics dedicated SQL pool that contains the users shown in the following table.
User1 executes a query on the database, and the query returns the results shown in the following exhibit.
User1 is the only user who has access to the unmasked data.
Use the drop-down menus to select the answer choice that completes each statement based on the information presented in the graphic.
You have an enterprise data warehouse in Azure Synapse Analytics.
Using PolyBase, you create an external table named [Ext].[Items] to query Parquet files stored in Azure Data Lake Storage Gen2 without importing the data to the data warehouse.
The external table has three columns.
You discover that the Parquet files have a fourth column named ItemID.
Which command should you run to add the ItemID column to the external table?
